FordGuy100
Depending...I think its safer to have studs and boost 10-15psi. The turbo's in the kits start superheating the air around 12psi, so anything past that is not going to get you any gains. You can run more and see more gains if you have a intercooler, but its a good idea to upgrade. Russ has put on 60-1 wheels on them, and his boosts 13psi with his intercooler.
If you want to run more boost, then you have to start looking into other turbo's. OBS PSD turbo's would boost decent, as do DT466 turbo's from what I hear.
