Performance engine parts
ameristar1
The One Blue Thing
Steger, Illinois
Holset HX40, Schwitzer S300, HX35/40 hybrid, DT466 with a slightly smaller turbine side.
PSD turbo is a pain to adapt. Talked to Area Diesel about what would work in the 300-450hp range.
dyoung14
Is getting worn out
spencer,tn
well i am about to get a non gated psd turbo:sly so i can lift my heads off the block:D
88beast
pa
i hear theres a john deer injector that fits in these motors im looking into it so if i find anythign out ill let you guys know
FordGuy100
Silverton, OR
I've never heard of the JD injector...though that would be interesting. Maybe the tip will work though?
88beast
pa
i guy i work with has a buddie whos running jd injectors in his 84 he said hes going to try to find out what their pt number is or something but the my coworker claimed hes got some good power out of that motor they are the same size and shape same threads but i suspect its not a pintle style but something better flowing
Just remember that better flowing may not result in better running. The DPS Pintle-free injectors are proof of that.
ameristar1
The One Blue Thing
Steger, Illinois
Is there a multi hole injector option for the IDI's or do you have to adapt a multi hole injector to it? Can you run a DI style injector with the Stanadyne rotary pumps or are you restricted to the pintle style injector?
FordGuy100
Silverton, OR
We need to read into this...never even heard of this before. It would be crazy they make a injector the right length, right threads to put it in, and right thread for the injector line.
Try to get the guys number and call him.
FordGuy100
Silverton, OR
Moose injectors, talk to Mel ;Sweet
Most of the multi-hole DI injectors squirt sideways. Probably not the best deal for our pre-cups. Moose Mister injectors retain the pintle, but flow quite a bit more than stock. If somebody can dig up the video, that tells you more than words do.
ameristar1
The One Blue Thing
Steger, Illinois
I just saw the video comparison between the A codes and the Misters. Pretty impressive. How much are they going for anyway per set?
lewisstevey7
