Oil return
S-west
Ct
I know I have already talked about this a few times, but can I run the oil return from the turbo into a valve cover? I was planning on feeding it to the fuel pump block-off plate but my turbo is going where the ac compressor was and I want to make the return line shorter, so if it wouldn't cause problems the driver side valve cover would be perfect.
I don't see a problem with it....however other members may...so long as it's gravity feed to the valve cover you should be golden.
S-west
Ct
Ok ya I'm gonna go ahead and do it. Other wise I need 4 feet of line and have to across the front of my motor.
ifrythings
BC
Another possible option, the oil return pipe plugs in each head.
Those oil return line plugs are in each end of the heads so actually we have 4 locations naturally for oil return. Nice pic too.:sly:thumbsup:
Cv axle
