Oil in coolant
Fordfan90
Idaho
hey guys my 7.3idi non turbo has oil in the coolant. I just changed the oil about 2 weeks ago but haven't gone through any. Any ideas before I pull the oil cooler and rebuild it? The radiator is shot so I'm buying a new one. I just want to know what else could cause oil in coolant.
shawn deere
nebraska
Going a new radiator? I just upgraded to an aluminum, the copper one was good as far as i know
austin92
Brazil. IN
My first thought would be head gaskets.
DaveBen
Ukiah, Ca
Non turbos generally don't blow head gaskets. Check the oil cooler. They do cause oil in the coolant.
Fordfan90
Idaho
I will pull it tomorrow I have the new kit to rebuild it. Do I need to use a press to get it back together?
Robert 85f250
Central California
i just did my oil cooler last week, no press. i had two friends pull on both sides as i tapped with a 2x4 and hammer to get it apart. lay something down for easy cleanup first. to get it together, i used a jack, block of wood, and the rear bumper of a truck to get em together. grease helped it go together easier, a tip i read on here a couple different places
Hydro-idi
Lodi, California
Okay let's hold on here guys. If you blow a headgasket, you do not typically see oil in coolant as a result. You would either see exhaust gas bubbles in cooling system, white sweet smelling exhaust, or an external leak.
And yes, even non turbo engines can pop a headgasket, especially 6.9's due to smaller headbolts.
Since oil psi is greater than coolant pressure, the most likely cause of your problem would be a failed oil cooler o-ring. They are kind of a pain to rebuild and have always taken them to a shop. If it is in fact the oil cooler, make sure you use a reseal kit that includes both the green & black o-rings. If all 4 o-rings are black in color, that is the "cheap" kit & will eventually leak on ya.
rustygold
conway Arkansas
I would say oil cooler them seals get so hard over the years.
Sent from my SAMSUNG-SM-G870A using Tapatalk
shawn deere
nebraska
I did it myself by hand. Might have gotten lucky tho. I put a knee on it, used a hand to line it up and another hand had a pry bar that i tapped on the lip. It snapped right in for me.
To get it off there are about 3 ways to do it.
1. Pull engine. ( dont do it)
2. Diss assemble under the hood and take it out in pieces
3. Remove motor mount, use a jack to lift the engine a bit to get it out
4. Remove power steering pump, and steering column. ( thats what i picked. )
shawn deere
nebraska
Is the aluminum a good one?
Hope so! Lol
From what i gather on heat transfer copper is the best, aluminum is second, and brass is trailing far behind. I believe the copper radiators are mainly brass. Ive got a turbo and im cranking it up, felt like i could some extra cooling power.
Fordfan90
Idaho
My kit has 2 green and 4 black is that a good kit?
shawn deere
nebraska
Might be the wrong kit actually.
The old 6.9 used a 6 ring deal. 7.3 used 4 ive heard both ways if there interchangeable or not. Someone who knows will chime in im sure
Fordfan90
Idaho
It has 2 green o rings with two black and the gaskets that gone on the block then in a separate bag it has two more o rings. I was looking under the pickup today sense at work I didn't want to put it on the lift. I found coolant on passenger side on the bottom of the motor on the starter and power cable. The bottom of the radiator leaks a lot could that be from that? I looked all of the place and can't find where any other coolant is coming from I just did the t stat a couple weeks ago in it and it's not leaking. Any idea?
MtnHaul
California
Passenger side coolant leak I would inspect the hoses going to the heater core. And you should be able to get the cooler together without a press. I used assembly lube and one side popped right in but the other needed a bit more effort--still not that bad. I actually just held one end against my flatbed and pushed on the other with my chest. Not very elegant but it got the job done.
IDIBronco86
