oil drain plug thread size
Dave 001
southern NJ
Time for an oil change, it needs a new drain plug gasket, and I want to pick up a gasket ahead of time. I think the oil drain plug thread is 1/2" - 20. Can anybody verify this?
Rockauto says up to 1989 is 1/2" - 20............1990 and up 14mm - 1.25 Other sources say 1/2" - 20 from 1983 - 1994. What is correct? Thanks.
justinray
Contributor
Cleveland, Tx
They didn't change the thread count or size of the hole between years.. Not unless someone messed up changing oil, and put the wrong plug in, because a 14-1.25 will crossthread its way into a 1/2-20 hole.
ntjapkes
