soggybottom
So I have been having hard starting issues, and decided to install clear lines at my return lines to see whats going on.
I started with the line from filter head to passenger front injector cap. There were no air bubbles, and the line stayed full of fuel with the truck off. I then did the line from the rear driver injector cap to the connector where all the lines return to the tank. This line has no fuel even with the truck running. Does this mean one of my driver side injector caps or lines must be leaking?
Truck starts excellent when warm, or if it has been sitting for only an hour or two. Glow plugs are new and working, but I have to crank for 10 to 20 seconds after the truck sits overnight or all day at work. When the truck does start it runs very rough and smokes a lot for a minute or two.
Thanks.
Thanks.
