alright, well I've been told about a few pretty bad stories. People forgetting to torque rod bolts, put pistons in, and many other crap far worse than my mistake.
The reason nobody found the pics is because I deleted it last night.
Watching everyone try to guess is getting painful and probably irritating to others, so f*ck it.
I put that piston in 180* out. I don't know when it happened or how, because I have pics of it installed properly, but it happened. This caused the gasket to get HAMMERED. Im surprised it lasted 1200miles.
I took pics, you can see the path the combustion took , as it was coked onto my cylinder... about a 3/4" wide path from where the pre-cup fired, straight down into the gasket, no spreading.
That being said, a few things I have to look forward to, is probably better cold start ability. I bought a block heater to install this go around.
Less smoke at cold start, and once warm, and I cant imagine the engine running smoother, but I cant imagine that it wont.
Also, probably more power!
I will post pictures later.
