88 Ford
He said he's going to try to have it done before dyno day. I'm glad it was just a gasket. Coulda been a lot worse than that but I bet it was fun while it lasted at 38psi.
It **** the head gasket out of the pass side lower corner.
Damn that's some power!!
Its likely not a total "apples to apples" comparison, but my Cummins when it just had a single charger was only running about 45psi. With Water ****, and all the goodies, & 45 psi it was a touch over 525 rwhp & 1400 ft lbs IIRC. I'd venture to say Justin's rig isn't too far below those #s.
Considering that the cummins is direct injection and has an overall higher efficiency rate, the idi's are probly handicapped at the same boost and fuel levels....
Ya or what ever Hypermax used...
Look here too BTW he only used oil for a lube on the head studs and god only knows how many times he ran them up and then down and up to torque again...That is critical and unless your willing to throw out a set of brand new HG you pretty much gotta do them all up....undo the studs and re torque em over n over about five times if I recall what Gary says ARP says.
So looking further there could be more issues as that HG gets compressed and released. I would install a new HG once the fasteners are on their final torque JUST TO MAKE SURE...there is that little less chance of failure
http://www.youtube.com/watch?v=6-XXVk_vwKw
