Well I think I found a place. They seem to have the right answers and can do any balancing I need/want.
I pulled out the Victor Reinz head gasket set that I bought second hand. Seems that the PO must have needed the valve seals, injector nozzle washers, water jacket gasket and a few other little o-rings. Either that or they got lost in storage.
I am a little concerned about the quality of the gaskets themselves. The quality looks less than impressive. Especially where the cooling passage inserts are on each upper corner.
I want to order the things I can ahead of time and this is the list I have so far:
1- Valley Pan Gasket (Felpro) $43
1- Timing cover gasket set (Felpro) $17.75
1- IH thermostat and water jacket gaskets ($??) (Anybody know if there is a high temperature version out there - like a 203F? and a part number?)
Some questions:
Will I need new injector nozzle washers? (If so, where can I source them?)
My front main used to leak- I changed to Delo 400LE and it stopped for a while, but now seeps a bit. Should I wait until I tear it down and see if a speedi sleeve is in order?
What do I need to do to the oil coiler? Are the o-rings another part I should get from IH?
Is there a preferred break in lube for the camshaft?
Sorry about all the questions, but its been a long time since I've been into anything bigger than a motorcyle motor AND its the first time I've ever ventured this far into a diesel.
Heaths post today was an awesome look into where I am headed and I can't thank him enough for the great pictorial!!
