jam sandwich
So, Im preparing this truck for a 400 mi trip and I want to be sure I don't end up broken down on the side of the road.
I've noticed my coolant gauge NEVER gets above the N mark while driving (I drive 40-50 miles roundtrip to work)
However, this morning, I looked down and noticed the gauge was at the halfway point (around the O and R) I watched closely, and then all of a sudden the gauge just drops below the N again out of nowhere
I was going about 70-75mph @ 2600 rpm or so (4.10 gears) I maintained the same speed during all of this.
If I idle the truck the coolant reading never goes above the N mark either.
I know these old ass gauges arent very accurate, but should I be concerned with such fluctuations? I recently had a coolant flush and added SCA back in. My overflow tank looks relatively normal, its a little offcolor but not as bad as it was when I had oil leaking in the coolant (I replaced cooler o rings)
I've never seen the temp gauge go past the halfway mark.
I just want to be sure this truck is roadworthy before I make such a long trip in it.
Would replacing the temp sending unit be worth it? The rest of my gauges work relatively well, and I've replaced both battery ground cables and a couple more ground cables in the engine bay.. Are there any other grounds I should inspect or replace?
