My Big Blue Ox build....
Lmao tyres 245 75 16 ..not big
Tool let me check see ifn can find details...yes its slick...got it and CSEK at same time
400 km road trip yesterday....ok so in very tight turns in parking lot...bitta buck heave ho but acceptable. No ill mammered behaviour on roads.
Gearing is ideal for truck...runs fantastic w 4.10's its ideal but I imagine when I run 38's I should run considerably lower gears.
Engine is burning oil and blowing blue constantly whilst driving...so engine re n re in near future.
Going fill truck again to brim...and determine actual fuel usage....scares me ...
Thanks for looking
Tiny 4x trip...mostly 2x...damn locker...rofl
Ended up the Fairview above my place...at small lake..
Easy road even mini van made it...
So have...HAVE TO wire 7 pin flat RV trailer plug into my truck...
Starting by making components...for examlle main BRAKE and Bat + wires in loom.
I use semi trailer style connection boxes. Tap into rear tail light harness w a 4 wire trailer plug...cut off plug and wire to the box. A single pigtail then wires to my plug. Also adding a 7pin plug into the box fkr 5TH wheel/Goose neck or a slide in camper.
Pics to come.
Got more wiring done...seems to be issue w controller for brakes...so may just purchase a brand new one....
Used to work...grrr
Seeing as got called back to work...bought this 28 foot trailer....
Other than being a bit low on power truck pulled it great inclusing some good hils etc.
Well crap...left work yesterday...filter light comes on...***..limp home...let cool...fell asleep.
Today go to work...sameo issue.
Decide order lift pump...nadda chance none zero zip to be found new in Vernon BC.
K one of sub contractors Keegan says buddy has dead 6.9 may have one
100 bucks delivered here by 2pm for him if he can do it..
1 oclock I had fuel pump in hand
So pull mine..***....no arm....see pics
So swapped in used and voila..up n running
So now heading back home n bout 45 min away...beer stop first....then home brews and pull spares tomorrow for work box in truck.
Thanks for looking
david85
Campbell River, B.C.
So....there's no electric pump in there?? I didn't realize they would run up & down the highway without a lift pump. Am I missing something???
laserjock
Almost there...
The IP will pull fuel to a certain extent. I don't think it's terribly happy doing it but none the less.
Ford diesels didn't get an electric fuel pump til... 1999?
It won't run 100%, but they will run okay with no lift pump on a tight system.
Heck, the duramaxs didn't even have a lift pump for awhile. Just the high pressure injector pump. Lol
david85
I thought maybe there was an electric pump added at some point and THAT was keeping the engine going. I always figured that these engines would idle ok but not pull a load unless it had good lift pump supply. Interesting.
placidoert
