moose power?
FordGuy100
Silverton, OR
I am positive you are right on that. That's what I've always thought, I mean just look how the hp and torque drop off the face of the earth. I think with a bigger turbo and an inter cooler, they could be making a lot more hp.;Sweet When the torque drops instead of staying flat, that usually means you are running out of fuel or air.
As the pump approaches the govened RPM, the govenor spring starts to limit the amount of fuel being injected. You wont ever get the fuel amount of CC's out of a pump at or near its govenor.
429idi
Layton Utah
Ya, I was going to say, if that's the case then the fueling isn't consistent. But, that means the pump doesn't push as much fuel at 3250 as it pushes at 2300rpm.:dunno
blown84
Conroe, TX, USA
if this is true, is there a way to allow max fuel flow, until the governed limit is reached, then it kinda kicks off like an EFI motor would? or is the only way to do it to remove the governor and invest in a tachometer?
Brianedwardss
Oregon City, OR
Maybe go to the 6.2L governor spring, and just not rev it all the way to 4,000 rpm's. In theory, you could have it governed at 4,000 rpm, so at 3,200 rpm you'd still have un-governed fuel flow. Mel's got the spring for pretty cheap too.
rhkcommander
Oregon
OP you can skip down to the bolded part if you dont feel like a heavy reading, its labelled "Supercharger part" and has my couple inputs. Sorry for the length, only read if bored I probably made an ass of myself..
Whats the maximum cc's we can hog a db2 out to, extensive modifications et al? I've seen a claim or two for a bit past 120 but IDK how or if it was even a db2 by the end. I've heard db4 plungers can make 150cc?
We can build the pressure, 6.9s with stud kit can handle the boost... but with 90cc's from a moose/120cc sm theres NO way we can get 300+rwhp with just #2 fuel and air.... Can the cooling system handle increased heat? The radiator I've got is the size of a boat.. But I've never had a chance to load it real heavy only a few tons. Theres always ****/water misting to cool her down
Everything said below is NOT tailored to N/A setups... because honestly you wont have much power N/A (no offense intended n/a guys but forced induction and diesel are a match made in heaven for performance:eek:. Only mentioning this to cover my bases)
High powered idis been' done before, its rare and costly but not impossible. Just too high above what most are willing or capable to spend and risk
Gonna toss out some ideas I've been mulling on for some time. I am probably off on a bit of points here but figured I'd say something and figure out what might be a good or bad idea
For more power, we need more fuel. DB2 limits, alternatives?
For the engine I'd go a 6.9 bored out some, for instance 60 overbored (4.06 bore, while 7.3L stock bore being 4.11 or 58.82% difference between the two for protection against cavi) and a stroke job around 1/8" will have a little over 7.3L displacement without the risk of cavitation like on the 7.3 IDI. Thats just covering the bare displacement... Then theres the fun on pistons & rods:D
Ceramic coat pistons, heads, blah blah blah. Coating only adds 0.0003 to 0.001 inch from what I've looked into... Teflon coating ought make things move a bit smoother too. Port & polish, open 'em heads up. studs of course... Cam grind. Balance the assembly to be safer at higher rpms, straightening if needed :dunno, etc. shorty or medium headers, either tri-y or 4-1 to the turbo... coat em too
Supercharger part \/
The new variable vane turbos coming out like the holsett hx35 reduce the problem of turbo lag and make supers more obsolete... supercharger + diesels low rpms are a bad combo unless you change the pulley to something smaller, this would increase the workload though but boost as well by increasing rotations at the super... Just something worth noting.
Turbos are nice in that they work up to match the load, as exhaust gases get hotter and thusly move at a higher velocity from the block,the turbo will speed up and feed even more o2 for combustion with its own RPMs independant of the engine, a super just looks at the RPMs and is limited thusly... A low rpm range combined with a super on a mechanical injected IDI sounds a bit barbaric LOL. You'd want to governor to 4k at least with a super. But it definitely looks awesome!
would be custom exhaust from headers to exhaust tip but a hx35 mounted to an IDI with upped fuel amounts, proper up & down pipes, intercooled, studded everywhere, opened heads, prechamber hole opened some, etc... ought be pretty beefy combined with a nice filter like the 6637 covered with ram air. You'd have almost no restriction when not moving, and when moving positive air pressure before the turbo lightening up the work it has to do. :dunno
Supercharger part /\
Most people I've seen or talked to forget a sem-important thing when routing intake and exhaust... The more bends and the harsher the bend angles, the more air restriction is created. Routing is more critical on fluids but it can have effects on airflow too. When planning an intake or exhaust you want it to be as straight as possible, when a turn is needed try to give it a large gentle bend(s) rather than a hard 90° turn or sharper, the gases slam into the ends and its as negatively effective as adding on extra piping.;Sweet. Can't remember what its called other than proper routing... its 8am and I've had no sleep so sorry but the easiest way to demonstrate the idea is to think of the difference between a 45° bend and a straight pipe... harsh contrast. A pair of 135°'ers can get you in the same place as a 90. sometimes harsh bends are needed but just thought I'd throw it out
As for injectors, I think the cummins injectors nozzles shoot out multiple points (whereas ours are straight out the tip) = more atomizing : commonrail injector as example: http://www.youtube.com/watch?v=g6q8d22RhGc see how that baby mists :eek:. I've read some modifying the injectors, we could probably use the nozzle from them multiple output injectors attached on our injector bodies,i think i've heard of hogging the insides out to hold more fuel or something along them lines, then theres pop pressure shimming, etc. With the head dissected in Mels photo, it looks like very careful machining could move the injector forward through the prechamber a short length to get a multiport nozzle inside while being thinner material,not sure how much material a injector reamer can eat through but if they are any decent it would be nice of someone to try on a junk head. combine that with a multi-port nozzle and it'd fumigate/atomize real nice or one could just open the nozzle hole up a tiny bit. I havent thought it through fully I figure some other brains can give it a whirl lol
As for making the engine DI from IDI, I've mulled it over a bit. The Precup can be pulled out, and a simple plug/funnel thing could be machined made from round bar stock and inserted with a dowel to help align it during installation. I'll upload a bad pic I just made in paint to help convey the image somewhat, see below http://www.oilburners.net/forums/attachment.php?attachmentid=33965&stc=1&d=1298307825. The tunnel could be more conular with the small end at the injector, and other tweaks but its a good enough napkin drawing to get a thought out. Only problems I could guesstimate would be the engine dynamic would be different (obviously), machining time/effort/costs to make the plug/funnel-doohickey-probably use aluminum round bar or something preferably higher temp capable:dunno. The only other problem I would see with an insert like that would be puddling/collecting of the atomized fuel - but honestly 2k PSI fluid is flowing so fast that it might not be a real problem esp. when considering the gains -DI combustion process is quite a bit faster than IDI combustion/precomb, esp. considering all of that reaction has to start in a soiled deoxygenated precup and burst forth from a small opening :eek:. Might be possible to cut in a groove for firerings in the theoretical chamber plug as well:dunno. Not sure how well that'd seal up to be honest but would be cool if it did work LOL. if only I had heads to sacrifice and skills needed. Either way the compression would be increased by filling the chamber, it could then be lowered some with some nice aftermarket pistons..
I think the major hinderances are that its not easy as in buy it off the shelf toss it in et voila powerhouse. And that we've all gotten use to accepting the motors for what they were and using them for workhorses. I'm sure with some modification a streetable, workable IDI could be had - maybe not modified as hefty as I mentioned above but thats what experimentation is for. Dyoung boosting 28 psi and only blowing a HG running reused head bolts iirc;Really. Stroking shows better benefits than boring when the cubes are equalled... I've seen people bore, but I have yet to see anyone stroke an idi on OB unless I've missed you accidentally. :eek:. Don't need a new crank, can get them grind 'n filled, is it viable? :dunno
Usually all I hear is: performance pump, intercooler,turbo, 3" downpipe, 4" exhaust, intake, propane/****/water (rare), then a 'all you'll get is 200hp or thats all these can do [without extensive mods]'. That photo of the white truck has an IDI that did 9 something seconds, so it isn't impossible but lately it seems to be treated that way. Haven't the 6.2s been hopped up a bit, where did they succeed that we are failing besides $ http://www.dieselpowermag.com/tech/...esel_engine_power_recipes/water_methanol.html is it the price tag alone? All I see in this article is inject nat. gas, propane, **** and $$$ for 300-500hp for the 6.2... Much easier to buy a cummins, turn the pump up and toss it in the ole ford I guess I can't blame people for doing that. I just don't think there should be a 200hp wall that cannot be exceeded without dropping exponentially more $$
I know someone in the world somehow mated a 8-cylinder-p-pump to an idi, that oughta do the trick on fuel if the db2 couldnt with the prechamber opened some more and more boost.... POWER? I know I know... price :puke:
Time to get a couple hrs sleep. Sorry for the book, I'm no pro I probably sound like an idiot and probably am ramblin since its 9am with no sleep. Plenty of people asking about power lately thought I'd chime in. Oh well
429idi
Layton Utah
The reason I wouldn't worry about boring/stroking a diesel is because that small cid gain can be made up very easily with extra boost pressure. A .060 overbore, and an 1/8" stroke will make a 438cid, you can make up for that with less than 1psi per bar of boost. Not to say that that wouldn't work, I just think you would want to put your money towards gaining max boost pressure first, also I think turning a higher rpm is key.
No, you don't sound like an idiot.;Sweet
rhkcommander
Oregon
That I didn't know LOL learning new stuff everyday. Gotta keep telling myself forced induction. forgotten diesels' site said the bore change alone gave the 7.3 ~15hp 22ft/lb over the 6.9, N/As though :dunno
Higher RPM could be done safer probably with the assembly balanced, governor spring swap outta the 6.2 i think it was for ~4k rpm, etc. But I think one of the dyno graphs here showed rpm not helping someone... out of the engines efficient range. been a while I'll go look for it
429idi
Layton Utah
Seems like it would be out of the turbos efficiency range. The turbos that are
typically put on these trucks tap out pretty fast. I would really like to see a dyno graph with a moose or super moose, and a turbo capable of flowing enough air.
Rolled coal from the moment David put his foot to the floor to the time he lifted it at the end of each pull. Not a black out the sun kind of smoke some of the trucks spewed out on the dyno, but she's got plenty of fuel. Just need a better turbo to get rid of all that smoke.
Heath
I think that the moose is capable of more than 200hp.;Really
88 Ford
San Diego, CA
I think you are dead on there too. I definitely think its the mostly the turbo but having such a low rev limit slowing the fuel doesn't help either. I think I might swap my governor spring out and see what it does. Its not like I'll be reving it to 4k all the time. :sly
dyoung14
Is getting worn out
spencer,tn
When i "tweaked" my pump and it would hit 4500, i noticed i could see the boost fall off past 3500 rpm but everypump is different mine was really worn out too so that probly had something to do with it
429idi
Layton Utah
I don't know if it's on here but, some people say the reason the db2 can't spin high rpm is because it can't fill up the plungers fast enough:dunno.
I wonder if someone was to use two pumps at 1/4 speed rather than 1/2 speed of the crank, and split the duty so they were alternating which one fired the injector if it could turn some serious rpm. It would take some dang big gears though.LOL Maybe that would be just as easy as an inline pump though.
rhkcommander
Oregon
How'd the exhaust look? I wonder if the diesel can burn completely before being exhausted, from the Idi nature?
88 Ford
San Diego, CA
That still could have been an air issue though. I know that you were producing high boost but the turbo was definitely pushed past its efficiency range. But who knows and as you said your pump was tired too. :dunno
88 Ford
San Diego, CA
Oh and I still think that a Moose pump could keep up a bit better if the governor was raised.
blown84
Conroe, TX, USA
dont you think a high pressure lift pump would cure this? run, say, a 50 psi lift pump on the frame rail in the engine compartment?
and what do yall think would happen if i just took the governor spring out? i mean, the only thing that limits how high i rev my 76 is my ear and the sound of floatin valves... hehehe.
Nanohawk
