Pulling the air across the impeller would create a vacuum. That's like saying you could put that turbo on a bigger engine, and it will suck the air through, there is no benefit. If the turbo is maxed, it's maxed, you wouldn't want to over speed it would you?
There are a few reasons I would choose to run the 112 first.
1. Lets say that you will be running 10psi, the supercharger will be putting out air at 200 degrees.
wa= (24.7 x .85 x 1650 x 420) / (639.6 x 660) = 35lbs/min
That's effectively turning your 6.9l into a 9.66l engine, you need a bigger turbo.
2. The second reason is that the parasitic hp draw from the blower increases with pressure and rpm.
At it's max speed, at 10psi, the m112 draws 58hp
Since it is a fixed displacement pump, it will flow almost the same amount of air at a given rpm no matter what pressure it is pushing. So, if you ran the blower first, here is what would happen. It would start pushing the air @10psi immediately into the turbo, and a couple of things will happen. First, the increased volume would go out the exhaust to the turbine aiding in spooling the turbo ( I would definitely up size turbine housing). The second thing that would happen, is when the turbo spools, it will need less pressure on the inlet to make the pressure ( max final pressure 20psi boost with the m112). To make 20 psi the blower would need to push only 7.35 psi (a pressure ratio of 1.5:1) that's 22.05 psia x 1.5 (turbo p/r) and you get 33.08psia- 14.7 = 18.375 psi boost, not exactly 20, but it's close enough for our reasons. That means the blower will only be drawing 45hp or less. In reality the blower would only be running a p/r of 1.3:1 4.6psi boost and drawing 38 hp max.
3. No matter what you do, if you use the blower as your final drive, or final compressor, the power draw will be there. If they will draw 58hp at 10 psi, how much do you think they will draw at 20psi?
I may have left something out, so I'll put it in another post if I did.
Also, in my first post I said I would use an m112, I meant m122.
An inter cooler will be necessary!
