now for what im doin to mine and it is goin to work and do not dare steal my ideas cause im goin to purposely leave out a coulpe things.
oh lets start out with that the engine is a 84 it is goin to have cut low comp pistons, havent decided on the twin turbos yet ported and polished 7.3 heads with fire rings and o rings drilled and taped for 120 hp 12v cummins injectors, 60 over engine rebiuld on everything, water ****, banks tecnicooler for a 99 psd with 3.5 boost tubes, either a custom built factory turbo 7.3 pump or a in lime 8 p pump off a v8 perkins that will be modded, air dog 2 200, custom ground cam, raised displacement above a 7.3, srtight 14 or 15.1 copresion, with fully equiped gages, and a few other trade secrets.
Ok, I was sent this quote, and was asked how much of this is even feasible. You've got a great list of things going here, however, it simply won't work. For starters, you're using a 6.9 block, which uses 7/16" headbolts, versus the 7.3 heads, which uses 1/2" bolts. Ok, machine the block to accept the larger bolts/studs, similar to the Cummins boys going from 12mm to 14mm. I'll give you that one. Fire rings, or orings, can NOT be machined into an IDI head, due to the prechamber extending outside the cylinder wall, and being a removable piece. Your ring groove will be allowed to move ever so slightly, resulting in a failed seal. You could o-ring the block, and use the wire to push up on the fire ring of a stock headgasket, but that's as far as you can go with that. 120hp Cummins injectors will definately help you make power, and of course you could machine the heads to accept them, but the spray pattern simply will not work in an IDI. Ever see the throat of a prechamber? Miniscule compared to the bowl in a Cummins piston, since those are Direct Injected. You say you're going to go 60 over on everything, I hope you mean simply boring 60 over. Since a 7.3 is essentially a 6.9 with a .110 overbore, I don't see your displacement being upped beyond 7.3 liters unless lengthening the stroke. Dropping your compression that far is by all means feasible also, but the thing will require ether to start at any temp. Custom cut pistons? Flycuts, enlarged chambers, shaved? IDI pistons aren't 'bowl' type pistons like those found in direct injected engines.
Why not just start with a blown 7.3 PSD, throw an inline pump on it, build it up, then add accessories of your choice? You're starting with direct injection, which will help you get ahead of the game. Your above listed comination sounds impressive, but in reality, is plain nonsense and a pipe dream.
I've been inside an IDI, built a few hi-po CTD's, and tinkered with several other engines, I'm talking from good old fashioned experience here. Go back to the drawing board, realign your plans, study up on IDI engine theory, and go from there.
PS, I'd love to hear some of your 'trade secrets', since you're plan has already been completely disected and proven wrong.
