Monster IDI limo truck with 4 WHEEL STEERING!
mabc926
Mojo
Hidden vally
That truck is pretty cool!
Depending on how good the work he did to it is, it would make a nice truck.
One thing that just doesn't make sense, why have rear steer WITH dually's?
Make it a SRW and take some of the load off of the steering.
rjjp
Needs to go test
Clare, Mi
They didn't reinforce the frame properly, look at the alignment of the cab to the bed.
mabc926
Mojo
Hidden vally
OH!
Another thing I noticed!
Why are the front tires and the back tires pointing the same way?
When using rear steer you want your tires to be turning opposite of each other, that's how you get the tight turns........
GOOSE
Happy IDI'er
Galloway Twp, NJ, USA
You could turn both front and back in the same direction and get the crab walk effect. I'd say that rig needs 4 wheel steering.:rotflmao I would definitely drive it, way cool.:thumbsup: I was hoping the body sag was cab mount related, not frame related.:dunno
it's alright...woulda been nicer with a decently done axle conversion whats a set of gears worth really?
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
I was wondering the same thing myself...why bother going through all that time, trouble, and money for a 6x6 where you can't use the front axle?
Wimp!!! :rotflmao I think that truck STILL has a shorter wheelbase than the 10-pax at work. Might be about the same as the 6-pax, though.
rear steer dually?? ***??? cookoo:confused: i wouldn't trust towing a radio flyer with that thing....
Was thinking the same thing...not sure how the hubs will handle two sets of wheels/tires, and how well the axle as a whole would hold the weight. I'd also like to see how the rear steering control works in the cab...is there a way to have it turn opposite the front wheels as well as locked and set so that it turns the same way as the front wheels?
Or maybe it's just for show? :dunno It's an interesting concept in any event...
tech51
San Antonio, TX
My better half said I'm to negative on stuff like that So to make her happy I will say not one thing about it...cookoo
Fordsandguns
Fords Rule
Eastland Tx
Did you guys read the question about the different gear ratios?
Q: with 2 different gear ratios how does it drive down the road in four wheel drive? Is it for show only or can it be driven like a truck?
A: it can be driven, but we never put the front gears in to match the rear. but, if you get stuck ,you can use it to get out. thanks for asking.
87crewdually
Southern Nj.
Stupid and waste of a tow vehicle. I can find alot better and more useful vehicles to buy than that backyard deathtrap. Plus in most states you cannot have rear steer on the road anyways.
Brianedwardss
Oregon City, OR
Seems a waste to make the rear dually-axle steer. I like the concept of an extra-cab crew-cab truck tho. Too bad, that truck SRW and a bit lower to the ground would be killer.
94f450sd
somewhere,ma
wonder how GM got away with rear steer on thier pickups a few years ago?
any ways it is a cool truck.really wouldnt trust the rear axle but could always swap in a regular dually axle.
