6 Nebraska IDIs
- Joined
- May 27, 2007
- Posts
- 4,247
- Reaction score
- 15
I don't think it was even 2 years ago that I put new track bar bushings in this thing but I guess you never know.
I agree with this IF the tires are close to original size. Nebraska didnt tell us what size tires are on it. Larger tires will increase the DW affect. Stabilizers help reduce the effect the larger tires can have.
If the DW is compounded or started by driving over a bump, its loose parts or a stabilizer is needed with bigger tires.
My 2wd has a stabilizer. One of the first things I did. Tires are taller than stock.
I have 35s and 38s with no death wobble, hell not even any vibrations at 80+mph. A steering stabilizer is just masking problems
Does not matter, you could be dragging the ass of the truck down the road w no rear axle and it would still have DW
are you postitive you dont have a bent rim, off balance tires, or lug nuts that are stripping? just trying to make sure basics are covered before you bury a bunch of money into front end parts
Hey Brad you've talked about caster once before. Both shops I've gone to around here say you can't adjust caster on a D60. They said its a bushing that is pre set and when its worn out you replace it, there's simply no adjustment to it. I've argued with them about it but I don't know what to tell them other than you guys have said the caster is adjustable.
I really don't think a bent rim would do what he says at 10MPH.
Something is seriously f'ed up and it doesn't sound like death wobble to me at 10 MPH. This isn't some sort of balance problem. Sounds like something needs some lube somewhere, I like the comment about the U joints too tight. Perhaps the wheel bearings too, but it seems to me if it was this bad they would have just destroyed themselves by now completely... maybe they have.
My moms truck has had a vibration/wobble in it for YEARS. I mean its been that way nearly since we've owned it. We've taken it to every suspension shop in the area and they all say that's simply how a Ford drives, if we want smooth buy a Chevy. I can't figure out whats wrong with it. How do you guys find wobbles and such? Its literally too dangerous to drive anymore, we parked it yesterday. It will be its final resting place if we can't figure out what's wrong with it.
Here's what its doing.
For the longest time it was a wobble specifically at 45mph, where the steering wheel and the entire truck would shake like you were breaking the warp barrier or something, lol. But yesterday we couldn't even get it over 10mph. The steering wheel shakes so bad its difficult to keep it on the road, the shifter in the transmission moves from side to side 10 inches, the dash bounces up and down 2-3 inches, when you get out of the truck to clean out your pants it feels like you just finished riding a jack hammer. Its bad, really bad. Please help.
