As promised, here is the part number and a visual reference for the fuel tank, fuel sender harness, connector (extra words for future search results).
So that's in and done. We'll see if everything is up to ***** when I start it back up the first time and switch tanks.
I reinstalled the overhead console today to wire up the switches. I'm probably going to cut another small piece of diamond plate out to fill the small gap underneath it. I left today with all the switches hanging out. Ran late tonight working on the wiring, but come Monday I only have the signal wiring to the relays to do. The perfectionist in me has a mild reaction to the holes not being 100%, but luckily I can't tell from the driver's seat.
From left to right: Aux driving lights, aux fog (flood) lights, mirror defrost (blue LED), lights on the front of the bed pointing into bed (we'll call them hitch lights) and the last on the right will be for rear bumper mounted lights later on.
This is my solution to a underhood fuse/relay box. I have an 8 gang fuse holder on the way that the power for all the relays will run through. I used the new damaged fender to mock up where everything is so I could get the placement down and went ahead and bolted the inner fenders to the new core support. So far today I got the running board lights completely connected to the relay and activated by the headlight switch (all running lights will eventually draw power from this relay) and the bed hitch lights completely wired to a dedicated relay.
I'm hoping that my replacement fender will show up this weekend so I can start painting them Monday. While they dry I'll be tying the marker lights on the mirrors into the running light relay and wiring up the mirror defrosters along with running most of the wiring for the grill guard mounted lights. I also cut the 75 ohm coax cable for the cophased CB antennas, so I'll be running them as well (so they can hang in the overhead console until I get the CB!). Staying home tomorrow and replacing one of our janky fence gates with a permanent one. One day my yard may dry out enough that I can mow the jungle back down
