First off, thanks to Typ4 for the reman injectors, install kit, return line kit and extra o-rings!
Engine before work, with all the leaves and other crap on top of the valley pan still.
And if anyone doesn't know, sanding rusty injector lines by hand sucks! I fully expect the paint to peel or burn off after awhile, but I used high temp (exhaust) VHT. I've found it to be one of the most durable that I can pickup locally. I have yellow on my work boots now
After the paint started to set and the fumes were evacuated, I sealed the paint booth and fired up the kerosene heater for a few hours while I worked under the hood. Tomorrow I'll get the clamps painted.
All the old mismatched crap that came off the top of the engine. Below that is the return cap that came off injector #4. Looks like it melted inside a bit.
When I hit the top of the engine with the blow gun, I caught 2 interesting things. One looked like the fossilized cap for the fuel head heater. May have been replaced at some point. The other is a flat rubber plug with a small nipple on it. It's about 1.5" around. I'll get a pic of it tomorrow as I'm curious about what it is.
