More work, less pictures today. Replaced the thermostat, oiled the vacuum pump with air tool oil, painted the under hood sheet metal (that bolts to the fenders), secured the fuel line, wired up the Duralift and filled in the holes above the windshield. Oh, and I cleaned the thermostat on the fan clutch. Last minute I pulled the overhead console so I could measure for my switch panel.
I wired the Duralift through the auxiliary oil pressure switch outlined here...
http://www.how-to-build-hotrods.com/electric-fuel-pump.html
I ran the ground wire for the relay into the cab to a switch (ground interruption) and wired up a push button to the starter circuit with a diode. Hopefully I got it right and will be able to push the momentary button with the key on and run the pump (to prime the system) without starting the truck! In doing this, I ended up having to fix a bunch of crap job wiring one of the PO's did. This weekend I'm going to pull the underhood fuse block bracket off the Bronco. I want to install a 92-96 fuse box between the coolant overflow tank and brake booster for the auxiliary lights. I have one that's been floating around in my spare parts for just such an occasion. I really don't want bundles of wires all over the place on this truck and the 9th gen underhood fuse box has a small footprint. I just need to decide how im going to bring it up level with the top of the overflow tank and suspend it over the harnesses that connect the in cab to the underhood wiring.
Finally took a side shot.
Old t-stat on the left. Guess it had been replaced at one point. Glad I decided to tackle it while doing all this.
Lift pump wiring looks like a rats nest with the fender off. Need to pick up some more wire loom tomorrow.
Diode for the prime circuit. Had an orange and brown/white wire that a PO had cut that didn't have any mates that I could find. Reconnected the key on only red/green wire and a solid blue wire. I totally forgot that the push button would backfeed to the "start" circuit and got luck enough to find a single factory diode in my tin of emergency fuses.
Frame clip and zip tie to hold the fuel line in place. Yeah, had just shot it with paint to cover the spot where I hammered it on.
I'll try to remember to get a pic of the lift pump kill switch and the prime button tomorrow. Plans are to get the pyrometer hooked up and finished. Still have to shoot another coat of paint on the battery trays and associated hardware. I'll be picking up bolts/nuts/lock washers for the core support bushings and may mount it up tomorrow as well. Gotta get on paint soon, I'm only about 80 people away from getting recalled to KW, but June's build schedule isn't complete yet, so I might get lucky and get everything done (and married) before I go back to not having any time to do much.
