Julianq7
So I turned up the injection pump a flat and straight piped to give her some more power and you can definitely tell it has helped. That being said my foot has gotten a little heavier on the pedal haha. Truck wouldn't start in the morning so I replaced glowplugs because I knew I needed new ones anyways. That is when I noticed the injectors had been leaking and diesel had been collected and sitting on top of the glowplugs. After replacing the glowplugs truck started right up. Next day after replacing them, it wouldn't start.
Do any of you guys know how to stop the leaking from my injectors? Do I need to replace them because theyre getting old or can I replace the seals (they never leaked when the IP was at factory setting)? Do you think this is why my truck wont start because the diesel is leaking on my glowplugs? Or maybe faulty glowplug controller/relay which fried them?
Any advice would help! I haven't driven my truck in almost three weeks and I'm dying to drive it again!!!!!!
Truck is a 88 F350 7.3 non turbo.
Thank you!!!
Thank you!!!
