razorback
what about the mr gasket micro diesel pump? is that thing as cheaply made as it looks?
Chris, The pressure will drop some with WFO, but 5 psi is plenty. Where was the pump mounted? In the usual spot on the driver's framerail in front of the tank valve? Not mounted horizontal or anyting?
Heath
I know lots of guys that run holley non "marine" pumps with kerosene and metyl alcohol. Sounds to me they are just using that excuse to keep the lawyers off their ass.
Usually the only difference between a marine rated pump and a standard one, is that it is hermetically sealed to prevent ignition of gas vapors in an engine room. I'd be willing to bet it is the same dang pump with a different label.
Yeah slap "marine" on anything and it seems to double the price...sheesh.
Probably.
Reading this I'm kinda glad I picked up the Carter that I got. Rotary vane pump, and yes it's MADE IN THE USA!
And someday I will actually install it!
