I had an odd deal, coincidently on the same rear passenger return line cap. Had put a new return line kit on last spring. Cap on #7 seeped a couple days, then seemed to quit, but started leaking again (along with #5) this fall. Replaced all O-rings with new viton rings. Didn't see any leaks, but continued checking and one day saw a tiny air bubble come out, no real visable fuel leaking but definately a tiny air bubble. So I popped that cap off and when I hooked the O-ring with my tiny hook to take it off, it fell right off, it was split! I checked the inside of the cap, and it was smoorh, some have reported sharp seams inside some caps. I thought this to be very odd, but lubbed up a new pair of O-rings and when rolling them on I saw the problem, there was a tiny loose burr of metal laying in the threads of the injector (perhaps from a cross thread event, maybe from the factory, these still being original injectors and lines off now for 3rd time in 20 years?). Anyway, as I rolled the O-ring on this burr would roll out of the thread a bit and, I assume, is what cut the previous O-ring. I removed the burr, cleaned up the threads, installed new O-ring, and so far, no leak.
