youngunbd
This is how to turn a one hour project into a three day escapade.
Step 1. Head up the nearest mountain range and lose your clutch fluid (next project)
When you are heading up the next incline, realize you aren't really able to shift, but floating it into fourth and limping to a rest stop will do.
Step 2. In the process you ****** at least one injector, don't worry, the fun is just beginning!
Step 3. Once home and with a new set of injectors the real fun begins!
Haha alright, all kidding aside, this was a royal pain in the butt. Number 8 had diesel leaking all around it, return lines and cap covered, all injectors had been great before that. BTW, whoever built the motor before me and painted it all blue, mismatched injectors, I had B's, BB's and an unmarked one.
I removed the fuel lines and proceeded to pop out injectors and clean bores. 2 was good, 4 was alright, 6 was oily, 8 was carbon coked pretty bad. Now as customary, my luck can't go forever, I started the passenger side with 3, which promptly split from its lower half. Having never seen this issue online before, my friend with a similar truck said time to pull the head and I replied with... like hell it is!
I ended up soaking it in PB blaster and grinding the head threads off said injector, some prying and more soaking got it out only to show the bore carbon coked like I've never seen! Lots of scraping, brushing, brake cleaner and all that good stuff was real fun.
This is where the crazy awesome fun time was. Number 3 copper crush washer was stuck, I mean real stuck. Tried the screwdriver trick, marred it. Tried with a phillips, marred it more. Couldn't even get a dental pick under it at that point! Day 2 rolled around and I spent 4 hours on it, using every tool I had! What finally did it, on day three I borrowed an electric heat gun, I heated that SOB up real hot, then flash freezed it hard with an upside down can of air, Three wacks with a flathead screw driver and the washer split and lifted the sides right up!! And holy carbon buildup batman!! It was also getting close to time to light the truck on fire at that point, I'm just glad it was 3 and not 7 or 8!
1, 5, and 7 were easy to change out. Lubed all O-rings, put all caps back on, lightly threaded all fuel lines and proceeded to bleed them out. Tightened them all down then started to run her. First it began with I didn't torque 3 down enough, wrench took care of that real fast. Then 1 started leaking from the base and 7 from the cap. Popped one to see that I didn't clean the seat well enough, another 5 minutes and she was back in. Now 1, 7 and 8 all have cap leaks!
My diesel tech down the street agree's I have air intrusion and tells me to drive a bit tomorrow, since I have errands to run. He says they may seat themselves, I'll still snag a few good looking caps from pick n pull while I'm there tomorrow, keep some lube and all the usual wrenches with me; good thing I just got a bigger tool box!
