remember these engines time on #8 plug. check if the air cleaner bolt is threaded into center of carb or held by a crossover bar over rhe throat of the carb. My point the center bolt for the air cleaner would be tightened down too tight and warp the top half of the carb. easy fix take off top half and measure with straight edge if warped it can be trued up. after straightening up don't reef down on it. Also the air cleaner housing need some bracing this was why it all started.
I can't believe I remenber all this crap it was 1977 my dad and brother both had travelall's. As I type I remember it was my dad's 1972 with 392. Good score.
