Idi 7.3 oil cooler
Cheapone1
New Jersey/ Phoenix Arizona
I changed my oil cooler part of the engine swap I did. The old ones were not up to par stripped and rusty I went cheap I knew better but well I’m silly some times needless to say they leak does anyone know the part number from ford or international that I can get the proper bolts I don’t want to ruin all my hard work . Thanks
Kizer
Denton, Texas
Welcome to the forum.
Here's a part number to research:
Ford Part No.: Removed
https://www.fordpartsgiant.com/parts/ford-bolt_-w300010.html Edit: removed
Use your Google-fu ... make sure I'm correct. There should be an International part number too.
If you put a description of your truck in your signature line we'll know what you're working on.
Good luck
Edit: I gave you the wrong part number .. it was in my notes from when I worked on my dad's truck.
Someone here will have it.
Alleycat
