tbrumm
Okay, I had a few minutes to get under the dash with a flashlight and tape measure tonight. From the centerline of the vacuum booster pushrod to the centerline of the lower mounting studs is 1-1/4 inches. On the hydrobooster, the distance between the centerline of the pushrod to the centerline of the lower mounting studs is 2 inches. There is that 3/4inch we are talking about! So, if I am thinking of this correctly, the vaccum and hydro booster both use the the same 4 mounting stud configuration to bolt up to the same exact location on the firewall, BUT the hydrobooster pushrod centerline is 3/4 inch "higher" (because that is just the way the darn thing is made) than the vacuum booster pushrod centerline. Here I was giving the engineers some credit for actually providing a little extra leverage to the vacuum booster based on the pin location. In actuality, the two different pin locations appear to result from the simple need to adapt two different types of boosters to both fit in the same truck in the same location. Oh, its great when the clouds clear and the light shines through! Thank you to all of you have who added your knowledge and experience to this discussion. I am very glad this pin location difference was brought up (yet again) so I had the opportunity find out about it before I started my install. My search for the FSuperduty pedal will continue!
