Humming block heater?
Cubey
Van dweller
After sitting a couple nights of low 20s, I decided to finally use ny block heater. It has a new cord I bought recently.
I plugged it in and went and did some other things, getting ready to go. I was outside nearby with a garden hose and sprayer "just in case", keeping an eye out for fire.
20-30 minutes later, I returned to the engine and heard humming. I quickly unplugged it, but it seemed to help. The truck started very easily on one glow plug cycle without any stuttering (broken cold advance sensor connection).
So I guess its working ok. It could have been humming at first but maybe traffic was drowning it out, or I just didn't lean in like I did at the end when I was just looking down in the compartment.
So, is that normal?
robw
seattle, wa
On both of my IDIs, they hum when plugged in.
I think you're good. More knowledgeable will chime in, I'm sure.
austin92
Brazil. IN
My 7.3 does it too, pretty sure it’s normal
Both my IDI’s, my 6.0 and the Jetta I had would make a hum. The only one I recall not making any noise is a lower radiator hose heater.
Like this:
The element in a freeze plug block heater is similar to what’s used in an electric water heater. Any electric water heater I’ve had you could hear when it was on.
This is what the block heater in an IDI looks like:
The big U gets hot, so it will make a noise while it heats the water.
