IH POWER
ALL MOTOR!
Everyone says there's a tag on the rear end but the only tag I can find is bolted on to the pumpkin under one of the bolts. And it has no ratios for rear ends on it. Is the tag on the axle itself? Or where specifically?
Your teeth won't rattle out of your head while doing 65 on the freeway.
My door tag is gone, but heres what the tag says,
2 V126C
3 . 55 10 2 7C28
Because with 4.10 gears my engine spins about 20 percent faster than a similar truck with 3.55 gears
That's kind of ironic becuase I always thought I had really low gears because 1st gear only takes you to about 10 or 15mph (if your really making it scream) and second is about 25-30 and you gotta shift, thirds about 45-50 and in 4th gear going 65mph on a flat its running 2500rpm. So I always thought that was kinda slow. But I guess not haha
