BP6.9
hey ive got a question for u guys, i have a ats non waste gated turbo im puttin on a 86 6.9 with new internals and lowered compression to 19.5:1 and im gona stud the heads with copper plated head gaskets ip turned up 2 meybe 3 flats, ill have all the gauges for it hooked up and im running a completely built c6 transmission with built t case for the truck and my axles are geared at 5:13s with lockers, wat kind of pull power can i expect from this set up? should i do anything different to build a reliable pull truck?
