MIDNIGHT RIDER
- Joined
- Sep 29, 2005
- Posts
- 4,639
- Reaction score
- 38
If you get an external regulator that has a free flow bypass back to the tank that allows the pump to run full tilt instead of running up against it's regulator spring all the time it will be quieter and will last a whole lot longer. Downside is those regulators cost a fortune, and for the price difference you could have just bought a better quality pump that was designed more for the application.
Here is the one that a lot of the Dodge/Cummins crowd are using with good success :
http://www.vulcanperformance.com/servlet/the-211/SimFlo-Bypass-Regulator/Detail
Thanks for the input about the pumps internal regulating system causing their early demise.
I will employ one of these regulators downstream of the pump, probably downstream of all the filters, so that they get full advantage of the pressure.
Should I then remove the pumps internal regulator ??
Thanks.
