Holley Red are garbage, what else quickly?
Clb
Another old truck
nannyfornia
My rollaway
Oh and not a cup holder in sight.
Real men can drive with 1 hand :sorry:
:flipa
Must not be a stick shift...
Have you ever tried to drink coffee, smoke a cigarette, eat chocolate, and chew gum all at the same time...?
Did not work out so well for me...
3 on the tree one handed is pretty doable. A truck or car with column shift will have enough slop in the steering to accommodate it.
Clb
Another old truck
nannyfornia
Lemme guess
Millennial
XOLATEM
Virginia... in the brambles
Lemme guess
Millennial
Bromhead: Those ********! They're taunting us!Adendorff: [Realizing what the Zulus are really doing, he begins to laugh]
No, you couldn't be more wrong! They're saluting you. They're saluting fellow braves!"
If millennials were making their bones in the 80's...sure...
mblaney
Ottawa/Ont/Canada
+1 on the Walbro. I have been running mine for years and never a problem. I also recommend pinching down the fuel return at the fuel head (the air return orifice) and slow the pump cylce down. Best upgrade I have done!
I don't need no steenk'n cup holder...
Thomas87
San Marcos, TX
I'm fixing to install an epump, looking at the Walbro Frb-5 or Frb-13 but can't decide. Will the frb-5 require a regulator? I mainly run regular diesel but do occasionally throw a gallon or 2 of oil in the tank from time to time. Also wanting to get more into waste oil in the nearish future, but it won't be in large quantities
Thomas87
San Marcos, TX
That's what I was thinking, wanting to keep things simple so will probably go with the frb-13 then. Unless someone has a different suggestion
Kevin 007
Full-floater
Nelson BC Canada
I run several. Mostly the 13. No problems. Just do it and don't look back.
I wasn't paying $800 for what took me just shy of $300 to build. Do some research on the matter and pick the pump that you think is going
to do best.
Well now I'm in the boat where I might need to go E pump, and I remembered this thread. Do you have part numbers or a brief guide on how you built yours? I would probably go the same route you did, as a high pressure pump with regulator sounds like the best bang for yer buck
KansasIDI
Hopelessly addicted to IDIs
Wilsey, KS
I just had a bad time with a Holley Red… this is getting ridiculous…
REM70
