Gauge change trans to engin temp?
blaz4wd
Fort Atkinson,wi
Afternoon everyone, well I'm sitting here in my truck and got to thinking(can you smell smoke) I'm going to be doing the E40d to the zf5 swap this month. Now I have a transmission temp gauge and the sending unit installed. Now could I take that sending unit and use it and my temperature sending unit???? Thanks Joe
no mufflers
rhode island
besides the gauge saying trans temp I don't see why not.
your referring to putting the trans temp sensor in the cooling system right?
Or maybe if you already have a mechanical temp gauge, you could use it as an oil temp gauge.
Macrobb
North Idaho
Yeah, I'd do this. I assume the sensors are the same, coolant vs trans fluid, but if not... oil and ATF are very similar, whereas coolant is completely different and might wreck any seals inside the sender.
blaz4wd
Fort Atkinson,wi
Hmm possibilities. I want to thank you guys for the input. I guess when I get going I prob go with the coolant temp for now.
Weld a boss onto pto cover of ZF...use it there....
Get coolant guage....more guages mucho cooler better
