fuel tank selector... what line is front and rear
junior20762003
VICTORIA TEXAS
like the title says i cant find a fuel diagram for nothing so could somebody tell me what fuel line is to what tank from the tank selector
thanks ;Sweet
If you go to the Pollak site and look at their diagram, the port closest to the valve is called the "main", which I assume is the front. The center large port goes to the engine and the larger port the furthest from the valve actuator is called the "aux" and and I am going to assume that's the rear.
Just shake the lines, easy to see which goes to the front tank. I believe it's the bottom line. Just don't get the return lines mixed up, or you'll overfill the tank not being used.
gandalf
Senior Member
CA &/or Maine
I've always found that pictures help, especially with my memory.
You might have to turn this picture a bit, rotate it, or twist your head. I've labeled things enough for my purposes. You might be able to read things.
Vinceslamer
