2000 RPM @ 60 MPH is not 4.10's. That's a 3.55 you got. For really great mileage, get down closer to the torque peak. The Moosestang, with 3.08 rear and a ZF5, turns around 1600 at 55 MPH, and gets 23 MPG.
That actually does sound right for 4.10s. With 3.55s, at 2000 RPM you should be between 65 and 70 MPH.2000 RPM @ 60 MPH is not 4.10's. That's a 3.55 you got.
Hmm, that seems fast for 3.08s. I get aprx. 1500-1600 at 55, ZF5-42 and 3.55s in our PSDs. I would kill to have 3.08s in the IDI Batmobile, to make up for the 1:1 top gear of the T19B (actually, the old wide-ratio T19A with 3.08s would be the ideal). Did they ever even make 3.08 gearing for the front?For really great mileage, get down closer to the torque peak. The Moosestang, with 3.08 rear and a ZF5, turns around 1600 at 55 MPH, and gets 23 MPG.
Sounds right to me too. With 4.10, I ran around 65 at 2200 rpm I believe, now with the 3.55, at 65, I'm at 1800 rpm. The rpm may be slightly off, but that's what memory recalls for me. Also these rpms will change with different tire sizes.
Sent from my SCH-I605 using Tapatalk
At 60mph, I'm getting about 20mpg at around 2100RPM.
At 65mph, I'm getting about 17mpg at around 2200RPM.
At 70mph, I'm getting under 15mpg at around 2400RPM.
I don't stomp on it, I let it smoothly upshift, it rarely gets above 2500RPM, and I live in the right lane.
Around 95% of my driving is highway driving, half is nighttime, and half is off-peak so I'm not clogging the roads.
1991 F250 E4OD 4.10 NA
No, they won't. Not unless you recalibrate the PSOM for the tire size. Or if you measure via GPS or mile markers. But changing tire size does not affect the relationship between speed and RPM as shown on the dash.Also these rpms will change with different tire sizes.
thats really good mileage....
I pulled 33x12.50s and went to a 30 1:2" 17 and guess what? Much better ride. No improved MPG with 4:10s. It prob pulls better, but still! 16-17 MPG for me.
