FordGuy100
I averaged right around 14mpg towing a 6500lb trailer from Texas to Oregon, usually doing around 65mph. Yours can do better.
With 33s, you're actually getting a little less than 1 MPG more than what you calculate, since your odometer is about 7% off.
thats odd, my old '84 with a banks turbo got about 20 hwy 15 city, and my '87 n/a gets about 15 hwy or city
everyone says these things get 20 mpg...
you can adapt the HF adapter so it will work. Just remove the valvestem in the end, cut it down with a hacksaw using a glowplug as a template, reinsert the valve stem and its good to go. My memory is that the correct length has the valve stem end just sticking out of the adapter. I have a thread on here somewhere about fixing the Harbor Freight compression adapter.Well I tryed to check compression with the tester I bought from harbor freight and the fitting it says to use for the 6.9 and 7.3 up to 1994 is too long it won't reach the treads so I found a shorter on in the box but the tread was a little coarser so I threaded it in a turn it two till it got trying not to mess up threads in the head on the drivers said front cylinder and I cranked it you could hear alittle bit of hissing but I cranked it till th needle stopped coming up an it landed at 350
