mccall52
A while back I swapped my TECA relay with the horn relay, no change.
Installed solenoid pack, no dice.
I noticed your truck is a 1994, does yours actually have an F4-prefix TECA installed?
It's about time for me to get my hands on one. Not to hijack the thread, but I have posted interest in the marketplace forum.
If you have a pressure gauge, install it in the gauge port on the tranny, Gauge port is on the drivers side just ahead of the shift lever. You should get about 180 to 250 PSI at 2000 RPM. Just jack up one rear wheel and put it in gear. That checks the pump pressure output. Be sure and block the wheels if you do that, or use a hose to the outside.
If only 15K on the TC, I would think it's good, if it rattles, it's *****. Gauge port is 1/4" NPT, if not you can always bushing up. Gauge should be 500 PSI, and glycerine filled for smooth sight, no needle bouncing.
Trans guy did a pump Mod? What Mods did he do?
Why ndid you change the TC in the first place?
Let me or trackspeeder know what the pressure is at idle and hi speed. Around 50 PSI at idle.
Have you set up an led in the cab to tell you when the TECA is calling for lockup? That is easy to do and the light should go out whenever the computer is telling the solenoid to lock the TC. I can check and see if the TECA in my truck has the F4 prefix - where do I look for that?
