finally! the long awaited engine build.
in a convo with that drunken french derivitave tin foil wearin hat **** @riotwarrior
and he came up with the perfect solution just now...
valve stem heights.
thats exactly what im seeing.
we installed monstrous inconel valves.
i bet the guy that did the valve job, didnt check it.
i mean, he only did it twice.
and BAM! just like that.....
Clb
Another old truck
nannyfornia
Same as push rod length.
Phawk.
Machinest much shop dudes?
This will be the third instance I recall.
Edit
So in america ' what does it mean when a shop sells a "rebuilt" part?
How do you not install correct length valves to the right tower height!???
I've seen reman 350's from kragen shipped with lifters and p rods clearley from used stores!
BS
Same issue in the ticking reman thread.
BS
Dayum.
these aint dime store sbc or sbf.....clearances stack fast....**** fast.....faster n speeding bullets....if u take word of machine shop....best be getting reach around first.....I AIMT saying it is valve length....but if u didnt check itnand it is....who is to blame?
Take no one machining thes 30 yo engines at face value...check every possible dimension...
***** yer as bad as Gary measuring to 0.0000000mofo01 so ...measure!
Sorry...drunken brain fart dirty cheat for ya Brian.....
Just as you did with rocker bolt bosses....
Pop off all rockers....dykem valve tips....and lay a straight edge along em....
Quick n **** dirty cheat bud....got yer back!
Drunkjewtinfoilhatwearingmofo!
Sadly I "thought" you had measured the depth of the valves in the heads and the heights of the stems. Might very well be the machinst did not know or care bout the specs. They do stack up quickly. Still don't think its the cam.....:angel::angel::angel:
cpdenton
Truck needs paint.
Conway AR
Now I want to check my valve stem height in my rebuilt heads. Valve recession measures properly on mine.
I have looked, but can't find the height. Anyone know what the spec is?
yes you did mention it Laser, but sometimes it takes a drunken jew on a rampage to see the it.
and it usually takes me 3 or 4 times to go through an issue.
in my mind i had cam on the brain,.
but i see the light now.
i plan on putting it together again today and getting her up to temperature.
if the oil press is fixed, i will be calling summit for adjustable pushrods to determine my final length.
then a call to Smith Bros.
i have a good 1/4" to play with when it comes to the roller rockers.
so this issue will be resolved.
what can i say, im hard headed.
x2! but i did use new valves, so the likeliness of the machine shop didnt check it is highly probable.
and the manufacturer most likely left them long.
im not pulling the heads unless i have to.
laserjock
Almost there...
Just yankin' your chain. :D
I'm learning the same as everyone else. Could have been any of us.
as a collective, we will get through it!! every issue, every time!
as ive only been apart of this place for a short time, i consider you guys to be part of my extended family.
yes even the drunken jew. hes like the goofy step brother you just wanna go into your tree fort and shoot frozen paintballs at LOL
Nanohawk
