So on my 85 6.9 about two years ago I put a new pump and injectors in from conestoga. Truck smoked a lot more than it used to, but it's a non turbo. I didn't think much of it but put a pyro on it just to be safe and the truck always seemed to run a bit hotter than my 7.3 but it really was never near dangerous levels but I'd see 800-900 empty on hills that my 7.3 runs at 600 all day on. My 7.3 is also way heavier, and in overdrive instead of 4th (zf vs t19). The pyro on both is the same (isspro) and mounted in the same location.
This isn't a perfect comparison with all the factors, but I'm hoping some of the factors will help me decide what to start messing with first. My 7.3 (though non turbo) has a factory turbo pump turned up 3 flats with 80k from a totaled 94 bucket truck. It has the banks powerpack which is basically a different bigger intake in the grill area, the giant soup bowl that takes the bigger filter that says "banks power pack" you see on ebay, and the Y pipe is different than factory. I don't know that it was this way from banks, but it looks less terrible and also is 3" out instead of 2.5" out. I have it fed into a straight pass muffler that actually is a great mix of deep sound but cutting out the obnoxious noise. I'm not a stack guy but the 7.3 has a stack because our camper was changing colors. This truck tow a 6500 pound camper and it will get to 1100 on hills, but I can shift my way around it and keep 55 most place unless the grade is crazy and then 3rd and 45 is the limit. There is one 2 mile stretch that's all uphill and easy to maintain 55 to compare egt's and the 7.3 can stay at 55mph in overdrive and be + or - 950 towing the camper.
It just seems odd that I can drive the same hill in my empty 6.9 and see nearly the same egt's unloaded that the other truck has loaded. The 6.9 doesn't do worse if it is loaded either. It's just kinda like that's where it is no matter what I do.
This makes me think it's either timing or the exhaust on the 6.9 is killing me. When I got the 6.9 it had the factory exhaust the whole way, but the muffler had a hole and the previous owner gave me a 2005 super duty exhaust. I only have the muffler on it because it all fit perfectly and I spliced things together with an adapter right about where the bed and cab meet. It's a 3.5" exhaust and there's probably 3 feet of the old factory pipe from the y pipe into it.
I'm also wondering if this muffler is killing me, I never had the egt gauge with the stock setup to compare. It is pretty quiet by comparison, but I don't want to rip all that off for no reason. It just seems so odd that I hauled a pretty heavy trailer and my vac last year with the truck on the same hills and the egt's barely changed from what they are unloaded..
