2nd IP is on......
Still absolutely no better than before. I really don't even know what to say right now. i'm just so pissed about this whole thing. i dropped nearly a grand in a fuel system and and it is no better than the leaking, un-known miles IP and original lift pump that was on the truck when i got it.
same numbers as before as far as egt's and boost. I think something is wrong with my turbo though as well. as a good amount of side to side play. no in/out though. when i rev it with the intake tube off i can hear a little "chirp" noise coming from the turbo. So nearly $1,500 in air/fuel mods down the drain.
Don't even get me started on that royal POS they call an E4OD, who ever designed that should be castrated with a dull spoon and the shot in the head three days later. let him suffer for a while. my current shift strategy. take off, shifts into second, i mash on it right once it hits 2nd, it shifts straight to third and locks the converter....what the ***** is that???????????????
This IP does feel stronger down low than the other one, but that may be b/c this one started life as an N/A pump unlike the last one. this just has no balls up top, just falls on it's face.
oh yeah, i should mention that i now have to put up with 900 rpm being the lowest i can get for hot idle.....
Can barely break the rear tires loose on a dirt road when putting the pedal threw the floor from a dead stop.....
I wish i would have gotten out of this thing when i had the chance.
