I haven't disassembled the steering parts from it, mainly because it has more shielded steering column that i have in my F-250 ( E-350 is from year 1991 ) and for now it's on daily use.
Problem is that there is too much play on the steering, which makes it very tiring and hard to drive through the winter with icy grooves on the road. We have replaced the steering gear and that rubber joint before the steering gear and we have also checked that those aren't causing any play. So do you have experience what causes the play, it has to be between the steering wheel and that rubber joint, so is there some kind of u-joint that can cause the problem? It is automatic with tilt steering.
Thanks in advance for everyone...
