Any specific size/numbers on pet 'cook' ****** drain thing? I haven't done the swap yet but wouldn't mind getting the coolant from the block as well.
I'll cut and paste Okie/Baja ******'s post from 3-4 years ago, over on the "brand X
" site.
#4 (permalink)
OkieGringo
Senior Member
My Photos: (17)
Feedback Score: 0 reviews
Re: Draining Coolant from Engine
The block drains are on the sides, the one above the starter is a ***** to get at unless you remove the starter. When you remove the drain plugs, you will get very slimey from the antifreeze running down your arms and all over your chest. So, to make the next time easier/less slimey, i put in Baja/Okiegringo Block Drains...
Okie/Baja/******
BajaGringo Block Drains
The block drains are just 1/4"npt pet****s, available in the "HELP" section at the auto parts store. You need a 9/16" crowfoot socket that fits on a socket extension to reach in to tighten them (There's no room for a reg open end wrench). Then, cut up an old spark plug socket to fit over the pet**** to loosen/tighten. Once they are loose, slip the 3/8" rubber hose over the end of the pet**** and continue loosening the pet**** (with the other end of hose in bucket). Intstalling these is still messy and a bit of a hassle, but NEXT TIME it'll be a lot less messy and a lot easier. Smear 'em with anti-seize to make sure they turn 'next time'. I've already had to use mine because when I had the radiator 'rodded' they didn't have the right kind of antifreeze, and I was 200 miles from home. So I needed to re-flush the system and re-DCA it. This makes saving/reusing the expensive DCAs/antifreeze possible if you use CLEAN BUCKETS. I bought a special funnel that snaps into the radiator fill, and use a metal spray paint funnel/filter/screen just to make sure nothing too big gets back in there. Yeah, I'm a little '**** retentive', that's probably why my eyes are brown. BajaGringo
I added them to mine a few weeks ago(idea stollen from Baja) I confirm they are 1/4" npt pet****s and the 9/16" crowfoot is neccassary also.
End of pasted section.
Hope that helps.
