trugertha1
so i blew my transfer case up beating on the truck the other day..j/w if i had to grab one from an idi or just any 3/4 truck? thanx alot-matt
I would assume the transfer case would be the same as long as it's the same model
IE: BorgWarner 1356 from a gasser should be the same as a BorgWarner 1356 from a diesel (just an example)
F150's, F250's and F350's all shared the same transfer cases. Make sure that if yours is a 1356, that you take one off a truck with a 1356 as well. I believe the three models were the BW1345, BW1356 and the NP208.
Look at all three models of truck for a case though. My 1996 F150 had a 1356, which is the same as my 1993 F250.
