Dana 50 pinion seal leaking
DrCharles
West Plains, MO
Now that I've installed a drain plug on my '93 F250's Dana 50 front diff, and filled it with the proper amount of gear oil, it's started to leak at the pinion seal. I have a few questions:
  • Does this pinion have a crush sleeve or is there a shim pack so I don't have to worry about preload?
  • Can someone verify that the correct pinion seal is National 5778?
  • Should I go ahead and order a Speedi-Sleeve, assuming that the reason it started leaking is wear on the shaft as well as the seal itself?
I'll have the driveshafts down soon to rebuild the transfer case, so that'd be a perfect time to do this seal as well.
thanks
Charles
DrCharles
West Plains, MO
Thanks.
I know I can look for grooves... just wondering the odds of needing the sleeve too. I like to have all the parts in hand before actually disassembling anything - reduces the number of days I can't use my truck :) Guess I'll order it, since I could always send it back!
Does that sound like the right seal p/n? There are sure a lot of different ones... :dunno
DrCharles
West Plains, MO
I meant there could be a several-day delay in obtaining new parts. We don't have a NAPA store in my small town and mail-order is slow.
Obviously it won't take me days to work on! And I hate having to do part or all of a job more than once... But thanks for the thread bump.
