DrCharles
Now that I've installed a drain plug on my '93 F250's Dana 50 front diff, and filled it with the proper amount of gear oil, it's started to leak at the pinion seal. I have a few questions:
I'll have the driveshafts down soon to rebuild the transfer case, so that'd be a perfect time to do this seal as well.
thanks
Charles
- Does this pinion have a crush sleeve or is there a shim pack so I don't have to worry about preload?
- Can someone verify that the correct pinion seal is National 5778?
- Should I go ahead and order a Speedi-Sleeve, assuming that the reason it started leaking is wear on the shaft as well as the seal itself?
thanks
Charles
