fuzzydog
Sorry this is kind of long but I want to include as much info as possible.
My truck is a 91 F250 7.3 IDI (no turbo, no mods) which I have owned for almost 4 years. It generally does the heavy work in my household and we have a daily driver car.
My expansion tank just started overflowing coolant. Ever since owning the truck I have occasionally smelled coolant but the only evidence of leakage I found was a small purplish coloration where the overflow hose goes into the overflow bottle (I use Turbo Power coolant w/SCA which is purple, but is same formulation as the good old green stuff, and it is diesel rated)
I just came back from a 1000km trip - half the trip pulling my empty 16' flatdeck, and the other half the trailer was loaded with a car. No problems on the trip - the truck just continued to pull like it has from day one.
Today, I warmed up the truck in the driveway about 5-10minutes (it was -5C) and made a couple stops on the way to work (total distance to work is only about 10kms). It occurred to me that the heater was not putting out the heat I would expect but didn't think much more of it.
When I got to work and out of the truck the coolant smell was very strong and was actually dripping out of the engine bay. I popped the hood and the coolant tank was full and overflowing. Great! I came on here and started searching - quickly came to the conclusion that I have blockworm (unlikely as I have always used coolant with additives), blown head gasket or cracked head. But maybe not.
At lunch time I went home and when I got there the coolant tank was once again full and slightly overflowing, and there was definite gurgling in the tank with bubbles coming up. Arggh! not looking good. But, the heater was still not putting out the heat I have come to expect.
After lunch I go back to work and on the way there, all of a sudden my legs are bathed in this hot air blowing out of the heater. Parked the truck pointing downhill and no gurgling, no overflowing. ???
I should note that my factory temp gauge is almost always way over to the left towards the cold end but it does work because when I work it hard the gauge will come up to about the middle, then I hear the roar of the fan kick in and it drops back down. I just figure I have a very effective cooling system.
So, I am wondering if my thermostat is flaky? But would that produce pressure in the overflow tank?
Also, when I popped the hood at lunch time I noticed that my rad cap has 7psi on it. If I am not mistaken it should be a 13psi cap, right? That might solve my whole problem there.
It is very curious that this situation cropped up now, which is pretty much the coldest day so far this year.
oh yeah - the coolant in the expansion tank is clear, light purple and clean. No oil mixed in with the coolant. The oil on the dipstick is black and does not appear to be mixed with coolant.
and no white smoke. At all. Sometimes a puff of black but am told this is 'normal' so I don't worry about it.
any ideas/insights?
I will get a thermostat and rad cap today
any ideas/insights?
