I finally fixed my upper radiator hose leak. First it was leaking around where it attaches to the thermostat housing, new hose and cleaned that up. Then it started leaking at the radiator. Turns out the paint on the new radiator was flaking off, causing sealing issues. So I pulled the hose off and cleaned the paint off the sealing surface, and cleaned the paint off the hose, and now it doesn't leak coolant anymore.
So, after all that, I tested my coolant temps. Yes I have an aftermarket gauge. So, in town, it seems to hover around 200 degrees. When on the freeway, it hovers at about 210 for the most part. Occasionally drops to 205, but not often.
Is this normal for these? I wonder if my thermostat is OE or aftermarket. When initially getting on the freeway, it will generally go to about 210-212 on the gauge, then drops to around 195 before climbing back to 210 and holding.
Even with the leak, the engine never overheated, even with a load, albeit only about 5k lbs.
What's the consensus?
