punkmechanic
diesel tech
There have been a few threads the last couple weeks concerning coolant quality and cooling system efficiency. Namely the problems caused by one or both being subpar.
I think we need to establish a "baseline" of what is what on the coolant test strips, where to get what coolant and additives, and what makes a coolant system sufficient or less than adequate.
I for one have two temp gauges in the truck and dont know which one to follow. I have the stock one that gets its reading from the front of the block and a second isspro plumbed into the rear of the drivers side head. My stock gauge ( I know they are less than ideal, but mine still works) stays in the safe range (to me that is from midway to low, correct me if Im wrong, thats why I started this post). The isspro on the other hand spikes everytime I pull a grade. It usually stays below 230 but has gone as high as 250. If I see it hit 230 and continue climbing I pull over and let it cool off. My sig states what all is in the truck (hypermax, unknown quality pump, newer injectors, pump is up two flats, running 50/50 transdiesel, and I think my cooling system is plugged up.
When I bought the truck a year ago it had been sorely neglected. I have fixed what I have found and this is really bothering me (especially in light of the recent head cracks listed by another member).
What temps should the engine see and at what times. The cylinder head temps are going to the hottest of the engine and fluctuate the most (hence the reasoning for a gauge in the head).
does anyone else have a cylinder head temp gauge and if so what are you seeing for numbers? I really want to know what is up. I have the data but nothing to compare it too.
punk
punk
