Coolant Question
MADVAN
Levittown N.Y.
N.Y.
Do you have to test SCA levels in the 24valve motor? :confused:
Is it known to have cavation in the cooling system?
Thanks this is for a 02. ;Sweet
BILL
argve
Resident Fruitcake
Gwynneville, Indiana
Don't worry about Cavitation in the Cummins - that is a problem that plagues the IH engines. Yes you should use them in the Cummins but it's not a biggie... You will find that most Cummins owners just use the normal prestone type stuff and have never heard of Cavitation and you won't find it mentioned on any tech forums concerning the Cummins engines either. So as they say down under - No worries mate.
holtzer1
missouri
prestone is just fine, unless your a stickler for oem stuff, the mopar coolant isnt very expensive either.
Turbo Tim 1
Not Far Enough North, New York
By the way, the Prestone stuff won't have any SCA's in it. You would have to buy some fleetgard or other comparable anti-freeze to even have that additive. I use the Zerex G-05 which is what is used in the newer Dodges, it is a HOAT (hybrid organic acid technology) anti-freeze and it does have the SCA but I have never checked it because just as was said above, it's not an issue.
Hohn
Background: SCA are used for cavitation issues on liner-equipped engines. The flexing of the liners causes pressure waves in the water jackets, and the partial vacuum at the trough of these pressure waves can cause cavitation.
The Cummins 5.9 is a parent-bore engine (no liners). Therefore, it has no liner flex, and no cavitation.
No need for SCAs on the CTD.
argve
Resident Fruitcake
The Ford IH engines are parent bore as well but they suffer from the big C like no ones business. Thiers stems from the fact that the walls are so thin and not supported well enough to deal with the expansion and contraction that takes place...
Tinman875
Caldwell, id
I will have a product out soon for the cooling system. It is patented and trademarked, been at it for 3 years. It will go in line in your supply heater hose line, and filter out all the junk keeping you from a plugged heater core. first one like this to market. completely cleanable with a stainless steel screen. It has 2 ball valves one on each end, to shut off the lines while cleaning it. I have 1000 coming from a manufacturer. It's called KOOL KLEAN. here is a pic. those are not the colors, just for cad separation.
Mopar1973Man
Not here...
I've been using the standard old prestone antifreeze now for over 5 years. Evertime I've flushed the system it's clean on the inside. I change my coolant every 30K miles regardless of the qouted life span of the coolant. I prefer to be safe than sorry...
