8v-of-fury
BAMF FORD
OK.. It does seem that in that diagram.. there are two different O-rings.
When i took the cooler off the truck it had two smaller o-rings (outer ends of cooler tube) and two thicker non round rings in more of a rectangular shape (inner ends of the tube).
To be honest, the o-rings looked pretty good and were still in perfect condition. but the paper gaskets were non-existent (possibly where the leaks were?). I ended up reusing the inner thicker rings and using new outer rings and new gaskets. I undid the motor mounts but found no good spot to jack the motor from, so i did not lift the engine. The cooler cam apart in two pieces when removing it. New gaskets and gasket maker on i put the front head back on and tightened it down. I put the new ring on the rear of the tube and smacked the other header down on to it, also put the new gasket and gasket glue. slide it up in to place and used a pry bar to seat the tube in the front header. It popped and seated, i know this because one; I heard and felt it, and two; the bolts lined up to their holes. I blame the ****** paper gaskets.. There may have been some oil or coolant or both on the mating surfaces.. I believe they did not seat correctly.... Causing my problems.. I will now have to drain the oil again, I will be re-using the oil and filter... I don't really care right now.. luckily i only have water and soap in the rad.. no money lost there.. I will however have to go get some new paper **** gaskets.. as im sure the others are toasted.
Where do i jack the engine up from? there is no suitable place i found...
OLDBULL8 used a clamp to squish his cooler together, is there anything wrong with the method i chose? Do you guys think i just screwed up on the paper gaskets?? that's where it looks like it is FLOWING from. I mean if the cooler fit back on in its bolt holes lined up.. the ends would have to be seated properly right...
I need to walk away from this one guys
