One other thing to consider. If the ends are corroded badly on the taper (you will see it) it will tear the o'rings going back together. Smooth them up with a file, carefully not to extend the taper to far in.
Use lots of petroleum jelly on the o'rings and ends when going back together. If useing a clamp like I did be sure and keep the ends straight when squeezing back together.
